Moving to a new Laptop [Solved]
RoySlough
Has mastered Fixture Creator
I Use FreeStyler for: Theater
Post by RoySlough »
Hi, I have freestyler installed with all my lighting DMX settings (this includes some fixtures I have had to manually create myself.)
What is the best way to transfer all this to a new laptop?
Do I make a new installation then copy some files (which ones?) to the new system
Or can I copy the program folders (including sub-folders)
Thank you
kittmaster
Commited FS Forum helper
FreeStyler Version: 3.6.2
Re: Moving to a new Laptop
Post by kittmaster »
I've done this in my virtual machine for testing, do a backup of your current system, install freestyler on your new system, then use the restore, everything should come in like nothing ever happened.
Kings
Post by Kings »
I usually just copy the whole FS folder from one C drive to another and it works perfectly everytime.
kittmaster
Kings wrote:I usually just copy the whole FS folder from one C drive to another and it works perfectly everytime.
Agreed, I've done this also....
RoySlough
Post by RoySlough »
Thanks Guys = thought it might be simple but felt I should ask the experts first.
Re: Moving to a new Laptop [Solved]
Always test a backup you have made first before removing the old installation as I have had corrupt backups before (there was an ongoing bug report I believe)
Backups are more convenient but like people have said usually just copying FS directory works too...
