FS 3.5.2 stops responding during sequence load save Topic is solved
rickwwallace
I am using FS 3.5.2 on a HP slate 2 touchscreen. It has been working fine until today. When I try to load or sace a sequence or cue I get the error FS has stopped responing (close program). o matter what you do after this the program shuts down. I have reinstalled and tried to run it with different compatabilities but nothing seems to work, Anyone else had this problem or anyone have any ideas. I have a big job coming up in two weeks and would like to have this working again. Thanks
Nathanrs93
- FreeStyler Version: None
Re: FS 3.5.2 stops responding during sequence load save
Hey
Have you tried it on a different PC?? If it keeps happening everytime you are doing the same thing, make sure you submit a BUG report about this for the developer. Cheers
Submit a BUG report here
Regards,
Nathan
Regards,
Nathan
rickwwallace
I found the problem but I don't know why it has just started happening. I am using a HP slate 2 running win7 professional and when you have the touchscreen service running FS will not load or save a sequence or a cue. It is almost like you don't have access to the file system. When the touch service is not running (using a mouse) everything works fine. To qualify, using a mouse with the touch service running will not work. You just don't have access to save or load the sequence or cue. If you are having this problem the try it without the touch service running and see if this helps.
