ADJ Flat Par QA12X
Nathanrs93
FreeStyler Version: None
ADJ Flat Par QA12X
Post by Nathanrs93 »
Hey,
Here is a 5 channel fixture for anyone that wants it
Regards,
Nathan
American DJ Flat Par QA12X.pff
Enjoy!
(42.74 KiB) Downloaded 52 times
sirwesley
Re: ADJ Flat Par QA12X
Post by sirwesley »
Getting "Input past end of File" error. :/
Nathanrs93
sirwesley wrote:Getting "Input past end of File" error. :/
This should all be fixed now :)
sirwesley
Post by sirwesley »
Still getting the Input past end of File error. Anyone else having this issue?
Post by Jan_K »
Try this one.
American_DJ_Flat_Par_QA12X_5ch.pff
(2.55 KiB) Downloaded 30 times
I said any errors should be referred to me as i may still have the fixed versions!!! Try the above file any issue still and I'll try find the file!
Sent from my Windows Phone 8X by HTC using Tapatalk
Post by Jan_K »
Sorry thought that was solved an not an issue any longer.
redsoxjiminator
Post by redsoxjiminator »
Will this profile work if the lights are set to 4 channel mode? I am using freestyler but also have a RGBW 4C ADJ Controller as backup. The 7 flatpar QA12X cans will be mounted very high on stage ceiling so changing the channel modes will be very difficult after mounting them. The ADJ RGBW 4C is a 32 channel controller that seems to work best when the flatpars are set to 4 channel mode. If I need to switch from freeystyler to the controller I want to be sure they still operate normally using either controller. Is there a 4 channel profile available or can the 5 channel be modified? I have been playing around with freestyler in virtual mode so far as I am still waiting on the lights to arrive. Thanks for any info!
redsoxjiminator
Never mind...received the lights today and was able to change the profile to 4 channel pretty easily. Thanks...
Return to “American DJ”
