turn all cues off Topic is solved
coley65
turn all cues off
Post by coley65 »
is it possible to turn all the running cues off in 1 go?
thanks
coley
Nathanrs93
FreeStyler Version: None
Re: turn all cues off
Post by Nathanrs93 »
Hey,
I've used overrides where I've selected all the fixtures and blacked them out by turning the shutters off, it's worked well for me. It all depends what you are doing and how fast you need them back on. There is the intensity control that is helpful as well on the menu on the right side.
Regards,
Nathan
coley65
Post by coley65 »
Thanks for the reply I can do all that you have suggested. However I need a 1 key press to turn the actual cues to stop running. I have set up a cue which turns everything to 0 but in effect the cues are still running.
Regards
Coley
Nathanrs93
Hey,
I don't believe it's possible. I believe the only way you could do is with a number of overrides i.e Blackout, Stop Movement, etc. Then if you make sure restore values is selected on cue list it should reset everything correctly back to the start to start again.
Regards,
Nathan
