Question about a minor problem
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Hey folks,
So I was running a setup on Friday 8th March which had a pair of Martin Mini Mac moving heads running and also an LED light. The problem I had was when I brought the LED in one of my moving heads kept getting effected by it and made the motor run slower than it should have been, so I wanted to ask why is this??
I have few ideas what was causing the problem but just wanted to ask, as it might have happened to you and you know how to sort it quickly?
Regards,
Nathan
Kings
Commited FS Forum helper
Re: Question about a minor problem
Post by Kings »
Check the DMX output when you 'bring in the LED' fixture. If you see a corresponding DMX value change on one of the mini mac channels then it will identify if it is a programming error.
Nathanrs93
Thanks Kings,
I'll be sure to have a play about with this again when I get a few minutes spare to myself.
Regards,
Nathan
