Hello everyone,
I Need your help. Would it be possible to have a fixture file for the showtec Phantom Spot 150 HTI
and the Showtec Genesis VI!
As I work, i currently don't have the time to do it and we will use these fixture friday.
Thanks thanks a lot!
Skartounet
Fixture needed: Showtec Phantom 150 HTI - Genesis 6 Topic is solved
polysix
Re: Fixture needed: Showtec Phantom 150 HTI - Genesis 6
Check http://www.freestylersupport.com/fsforu ... f=23&t=965 for the phantom mk II fixture
