Sync Light Show!
trapgunner
Sync Light Show!
Post by trapgunner »
My last sync show, the music is called "Escuridão" in english "Darkness"
http://www.youtube.com/themilitiatv
Hope you like it, and please if you have some question or feedback, I'll greateful to answer.
Re: Sync Light Show!
Post by Jan_K »
Hej trapgunner
How do you synchronize sequences and the music.
I guess that it is made in more than one sequence.
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Hey,
It was made really good and I'm looking into doing something similar for the work I do. If you have any tips or anything you think might help, then let me know.
Regards,
Nathan
trapgunner
I have some problem to make different lights simutaneous, because I use the tap to change the steps of a sequence, and you dont have different tap for differents sequences, but I'll try to make some tutorial for it.
