Download Link for Easy View Beta dissapeared
burgi
Post by burgi »
Good evening everybody,
I reinstalled my whole freestyler and EasyView bunch on my computer. Unfortunatly I got the problem with noch showing beams of fixtures with shutters. I read several time in this forum the new beta version of EV would solve this problem, thus I tried to download it from nicolaudie.com, but I'm not able to find a download link to get it. And the "old" download link http://www.nicolaudie.com/downloads/fil ... c_beta.exe seems to be dead to me.
Can anybody help me with a working link, maybe ?
Thanks a lot in advance burgi
Nathanrs93
FreeStyler Version: None
Re: Download Link for Easy View Beta dissapeared
Post by Nathanrs93 »
Hey,
I believe I have a copy of the beta verision that I've found on my HDD that was in my old laptop before it died. I will be trying it out and then if it all words fine I will upload a copy for you
Regards,
Nathan
psychonauten
Post by psychonauten »
Hi guys, if you find the file, would you mind sending it to me as well ? Or maybe publish it somewhere if it is not violating some software license.
(I´m guessing this issue will be reported again and again if there is no solution posted here.. )
bjoneson
Post by bjoneson »
Looks like the Beta link is active again now:
http://www.nicolaudie.com/en/easyview.htm
Hambone
Band Member
I Use FreeStyler for: Band
Post by Hambone »
FYI, there has been a change in the new beta (3/7/13) that needs some tweaking to fix. If you run Easy View and it shows "DMX OFF" at the bottom right, the MEVP.dll file in your FreeStyler folder needs to be udpated.
After you've downloaded and installed the beta into your FreeStyler folder, go to the FreeStyler folder and find MEVP.zip. Extract the file MEVP.dll from the zip into your FreeStyler folder, overwriting the existing file.
This will allow FreeStyler and Easy View to talk to each other normally again :)
http://two-for-flinching.com
Nathanrs93
Thanks Hambone. I did post this in the announcement I did "Read me, if light beam is not visible" but it wasn't explained very well as I explained it ;)
I will copy your post and make sure everyone knows. Ta :)
