Hi All,
Is it possible to make the Override buttons page larger so that there are more buttons on a single page?
I have a midi 50 key keyboard mapped to the override buttons, and need to be able to trigger overrides from both pages at the same time, so that each key on the keyboard corresponds to an override button. Right now I can only map the left half of the keyboard and have to keep switching pages. This is problematic because the key assignment changes based on page, and I cant change the pages fast enough to be able to go from Par trigger to strobe etc in a single beat. I have tried mapping as best as I can to keep things grouped but there is no way around it, I need all keys permanently mapped.
Is there a way the window can be changed somehow? Or is there a way to assign MIDI to each individual page of the overrides? Willing to pay to have this done if anyone knows how to edit the GUI or the MIDI settings.
Thanks,
Steven
Edit Override Buttons, MIDI to each page
steven850
- FreeStyler Version: 3.5.2
- Spirit
- FreeStyler Version: 3.5.9
Re: Edit Override Buttons, MIDI to each page
By default it only possible to have all 180 Overridebuttons on one screen IF you use the touchscreen interface 2.
but i think you can also do this with Midi.
i use MIDIBOME's MT to manipulate MIDI and the thing you like to do can be done with the free version.
But you need to SEND 2 Notes to FS, like this.
IF button1 is pressed then Bome's MT send to FS Overridebutton1 AND TAB1.
IF button 31 is pressed then Bome's MT send to FS Overridebutton1 AND TAB2.
so in midi it looks like this AS example.
OverrideButton1= CC#1
OverrideButton2= CC#2
OverrideButton31= CC#31
OverrideButton32= CC#32
Override TAB1 = CC#51
Override TAB2 = CC#52
So IF Bome's MT gets:
CC#1 it send to FS CC#51 and CC#1
CC#2 it send to FS CC#51 and CC#2
CC#31 it send to FS CC#52 and CC#1
CC#32 it send to FS CC#52 and CC#2
the only issue is if you press a buttons on Tab1 and Tab2 the same time it can give Faulty outputs..
if you press it FAST!! after eachother then it should work OK..
i also First send the TAB CC# then the Button CC# this way it will first Switch to the TAB then presses BUTTON..
but im not totaly sure if this will work as i never tried this before..
