Detachable Sliders
Detachable Sliders
The right hand sliders would be great to either have them detach from the side so you cn move around like a window or its own window (keeping the right hand side pane) so if lets say i have a strobe i can click my fixture it then updates shows sliders in the window and i can then just drag and "slide" speed or intensity controls and always have them on display!
Return to “Ideas and Remarks”
