Hey Guys,
I recently bought the antari HZ-300 hazer and it's got great output, but it is just very loud. Any suggestions for a small, powerful, but most importantly quiet, haze machine that'll do the job and not crap out on me for a long time??
Looking for a quiet powerful haze machine Topic is solved
- Hambone
- Band Member
- FreeStyler Version: Beta
- I Use FreeStyler for: Band
Re: Looking for a quiet powerful haze machine
LeMaitre Radiance Hazer for the win
It's an expensive unit (around $1100USD), but it's very quiet (almost silent), rugged (and easy to repair if something goes wrong), and can fill an arena with no problem.
It's also extremely efficient with the juice. In most of the venues we play I have it set to run between 40-50% output, 100% fan, 15 seconds of haze every minute. We play 100+ shows a year and it runs non-stop for about 5 hours per show, so around 500-550 hours yearly. In that time, we go through about 3 liters (3/4 gallon) of juice and have only had to clean it once. You just can't beat that
Like I said, the units are rugged - ours gets bumped around quite a bit with no ill effect - the only time we had a problem was when we had a power outage that sent a spike down our DMX line and took out 2 of our moving heads and the serial chip on the hazer. I was able to repair it by replacing the chip (pulled it out, popped in a new one, done).
I can't recommend the unit more highly - it's a professional-level hazer and can withstand the rigors of touring
http://two-for-flinching.com
