MIDI control on 2 specific channels?
djferken
Post by djferken »
Hi there again!
If I have a strobe, and I want to control that strobe with a MIDI controller, how would I go about that?
Maybe like this:
Button 1: Blackout on/off
Rotary 1: Strobe Intensity/dimmer
Rotary 2: Strobe Speed
Is that possible?
Kings
Commited FS Forum helper
Re: MIDI control on 2 specific channels?
Post by Kings »
FS has a large range of actions that can be controlled by midi signals from a midi device but I don't think it will allow you to control the individual channels of a single fixture. You can always create a number of single step sequences of strobe actions that you like (eg medium strobe medium intensity, fast strobe medium intensity etc) and assign the to an override button. These overrides can then in turn be assigned to a key on your midi device or key on your keyboard (ie keyboard shortcut).
Post by Jan_K »
If you have the strobe on a fixed channel then you can use the "midi to DMX".
It is one of the external controls that midi can access and if I recall correct then you define which dmx channel to control.
djferken
Post by djferken »
Jan_K wrote:If you have the strobe on a fixed channel then you can use the "midi to DMX".
Thank youuu :D
Post by Jan_K »
Well finally.
I don't know how your fixture are created but if you look in the external control list http://www.freestylersupport.com/wiki/e ... l_commands then there is a Shutter faded and a intensity fader.
They correspond to the same faders in the lamp panel.
djferken
Post by djferken »
I'll just use the MIDI to DMX :-)
