Cue Button Not turning Hypergem off Topic is solved
coley65
Post by coley65 »
I am using a one step cue to run one of the in built programs of this light. When I deselect this play button in the cue list the light carries on playing.
How can I achieve it so when I deselect the cuelist button the light turns off
Coley
Re: Cue Button Not turning Hypergem off
Post by Jan_K »
Hej coley65
I am not sure that I am aming at the right issue here.
It will continoue until you set it to do something new. Deselect don't change that.
If you want movements to stop then make a seruence with a fixed position, could be center.
If it is only sequences with 1 scene then it may be an idea to use the overridebutton.
coley65
Post by coley65 »
Hi Jan
The fixture has four channels 1-function, 2 -chase, 3-speed, 4 strobe.
I noticed the restore values button within the cue list was not restoring the values.
Looking at the output of my pars I noticed that restore values only works when the channels are set to red green or blue.
So I set my first 3 channels to rgb and now when I stop the cue the light turns off.
Is this the correct way of doing this?
Thanks for the help as always
Regards
Coley
Post by Jan_K »
It sounds wrong.
But I may not be the right one to answer as I don't use cuelist buttons.
I will have a look when I gets home.
Maybe Spirit has worked a bit with cuelist buttons.
Post by Jan_K »
Hej again.
I have been playing a bit with this but don't have a clear picture of the restore but it looks like it restore correct.
But I noted that in the cue - cog wheel there is a "Restore only intensity channels" and in the Cue list button cog wheel there is a "Restore only shutter channels"
Have you checked these two settings.
Kings
Commited FS Forum helper
Post by Kings »
Instead of adding you one step sequence to a curliest button, add it too an override button. Engaging the override (you can choose the button to stay on, or on only momentarily as a flash button) will make it follow the sequence. It then returns to its normal state when the override is no longer activated. Perfect for strobe effects!
coley65
Post by coley65 »
Thanks for replies
I did a gig last night with the set up last night worked fantastic. The reason I have to use the cues and not the overrides is because I used the ipad app to control the lighting and the cues buttons and the override buttons are on separate pages.
I played for over 6 hours and not once did this set up let me down.
I would love further development of this app in respect of bigger buttons and interaction with the buttons of freestyler so you can tell what cues are running
It has taken me a long time to learn to use freestyler but the but last night I reaped the rewards I really enjoyed using it.
Thanks for the help
Regards
Coley
Post by Jan_K »
Just a small note.
If you use the override button then you sequences must only have one scene / step.
If it have more steps only the first is played.
There are more info on the wiki about that.
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
I like to use override buttons to change the beam, gobos and color options to my existing cue lists. Adds options to already programmed scenes. :D :fs:
