ETC Selador fixture
mulk99
I Use FreeStyler for: Theater
ETC Selador fixture
Post by mulk99 »
I am having trouble creating a fixture for an ETC Selador. My issue is that I can only create 6 colors and they have 7. I need the knowledge to adjust the template so that i can have 7 colors and have the mixing macro's understand what colors are what. I would post the fixture here, and will, but its on the other laptop at work. Any help would be great.
Re: ETC Selador fixture
Post by Jan_K »
Hej mulk99.
Please link to the manual. Makes it easier for other to look at the problem. :)
I just had a look on the DMX table.
The color control don't fit anything. There is no white no cto, only the RGB fits.
If I should do this fixture I would only place the RGB on the color control.
Then they fits the colors.
And then I think I would place the other on the gobo and gobo rot control.
It is not the nicest way but it will work and I will be able to have all control open at the same time.
You can eventually make 4 macro row with the color as the first icon and then 9 volume icons for each of the 4 rows.
And then use the "show in" to get the shown in the gobo panel.
Post by Jan_K »
