Sequence in Cue interrogation
Civette
FreeStyler Version: 3.5.2
Post by Civette »
I'm new to freestyler ( even new to DMX actually ) and I'm facing a trouble in the cue list window.
The wiki is pretty great but I didn't found an answer to what I'm searching.
I created one single very simple sequence with a moving head. It is working fine when steps invoked from the sequence editor and happens what is supposed to happen.
When adding the sequence to a cue list it run once, even if repeat is active. I "workarounded" it by adding the same sequence as a second line in the cue list and then it repeats again and again as supposed. is this normal ?
This brings me to a second question. Is it normal that sequences plays one after all in a cue list.
sequence 1 -> sequence 2 -> sequence 1 -> sequence 2 -> ....
I'm unable to stop a sequence in the cue list without stopping the whole cuelist.
My questions may seem very basic but, despite reading the wiki, I'm not able to be sure that noticed FS behaviour is the one designed or if it is an issue.
Thank you
Civette
Re: Sequence in Cue interrogation
Post by Civette »
Ok I got it
"Loop all sequences" had to be disabled
