Hello Freestylers!
Here are two Videos from a Testsession with my new Equipment
2x Showtec Indigo 4500
4x KONUO MH LED 60S (same like indigo 4500 but some other gobos)
2x KONUO MH LED 3603B
Controlled with Freestyler DMX
2x 1 Watt RGB self constructed Laser controlled with Phönix Live
In the next days i will make some Videos with my Full Setup on a Event!
My Fullsetup:
3x Beamers with shaped Screens with Resolume (controlled via DMX)
2x 1 Watt, RGB, 20k Scanners, self constructed Laser
1x 2 Watt, RGB, 50k Scanners, self constructed Laser controlled with Phönix Live
First Test with new Equipment Topic is solved
- djSupport
Re: First Test with new Equipment
Hi Good vids, I edited your post for the youtube links to work you just add the bit after youtu.be/ for it to work..
