Problems with Studio Due Giant
Nexo
FreeStyler Version: 3.5.2
Post by Nexo »
Hi!
I have some problems with freestyler.
We use 12 Studio Due Giants, 1 6ch Dimmer and a smokemachine for our liveshow.
I Finaly got everything up and running with the 3d visualizer.
But i have some serious problems with the shutter on the heads.
I can´t get the shutter to be open, it strobeing in different speeds.
If someone can help me over skype i will be more then happy!
Robbin861201
Nathanrs93
FreeStyler Version: None
Re: Problems with Studio Due Giant
Post by Nathanrs93 »
Nexo wrote:Hi!
Robbin861201
Are you saying that the shutter will only open when in strobe mode and not when you click "open"?? If this is the case then you need to download the new 3D BETA view version
Click here for more information and link to lastest 3D BETA version
Just to let you know that there is a .zip file in the files when you download the new BETA version, this will need to be extracted before you can use it other it will keep crashing on you. If you need help on this or are stuck PM me and I'll be more than happy to help. Good luck :)
Regards,
Nathan
Forum Moderator
