FS and SBDJ S2L, cues etc - anyone use it? Topic is solved
malykazio
Post by malykazio »
I'm using freestyler about 2 years. Now I try to synchronize light with music - I try S2L plugin - but I can't configure it. It didn't recognize beats properly. It's to sensitive or not enough sensitive.
So I try to use SBDJ S2L for VirtualDJ plugin - after many, many hours spent to create new sequeces, congiguration etc - i'm confused. When FS gets beat from VDJ - something wrong is going on.
Fe: I have only one cue with 15 scenes. From time to time FS baypass some beats (jumps to fast to next one) It happens in different places with every cue I made.
Unfortunately there is something worse: FS baypass steps in cue. FE: I have 4 sequences in Fast cue switcher.
All of them have 15 scenes. First was played with all steps, second - only first step or two, third - for steps etc.
Sometimes only 2 steps from first sequence at loop...
The same thing happends when I turn off react to sound and try to react to manual tap to give correct tempo - baypassing steps in sequence and jumps to next one. :/
And at finish: Buttons in Fast cue switcher: Why when I save cue to button and I press it - all sequences are playing together. Maybe developer of this software culd make any option to play one bay one in futture version of FS? I think it's more usefull. Now I have to save only one sequence in cue if I want to use it correct.
Or mayby someone have solution how to play sequences in cue on by one using SBDJ cue plugin? (without making 20 cue points in each song)
Regards and thx for your time.
malykazio
Re: FS and SBDJ S2L, cues etc - anyone use it?
Post by malykazio »
I will answer myself :D
So, after FS upgrade from 3.5.0 to 3.5.2 all problems with sequence steps jumping are gone. Yupiiii :)
BUT! Ther is another (new) bug: If I have 2 sequences in a cue: first is set to "react to sound", second - "no react to sound" que player stops at the begining of sequence which is set to "no react to sound". Always.
Only if all sequences in cue are set to react to sound or all set to "no react" - everything plays perfect.
And my ask for buttons - to play sequences one by one instead all of them in same time is still open.
