KAM LED Hexaflower 1 DMX
Pidea
Has mastered Fixture Creator
FreeStyler Version: 3.5.2
I Use FreeStyler for: Band
Post by Pidea »
My first fixture file but, to my astonishment, it works ! Although the fixture is now discontinued they do turn up on eBay from time to time and some retailers are still selling them off discounted.
Here's the manufacturers page which contains a link to the manual:
http://www.kam.co.uk/index.php?action=p ... uct_id=285
The fixture file is attached and works on 3.5.2
Enjoy !
Note: this is version 2 and fixes a few issues that the original file that I created had. If you downloaded the previous version, please redownload and install this version.
KAM-LED-Hexaflower-1-DMX.pff
(24.28 KiB) Downloaded 30 times
Re: KAM LED Hexaflower 1 DMX
Post by Jan_K »
Hej Pidea.
Had a quick look on the fixture file.
It is a large image you use. Normally I uses round 60x60 pixel then it is possible to have more than 1 fixture on the screen.
Number don't appears for preset.
I guess that you mean the images in the for macro.
I can see that you have not added any.
Can you tell how you have tried to add them.
Pidea
Post by Pidea »
Thanks for the comments Jan, I'll fix the image file and will add the preset images as well when I'm back at my main computer. I'll upload the revised fixture file later this evening.
Post by Jan_K »
Have you updated this fixture?
Pidea
Post by Pidea »
Apologies - I completely forgot to do it but you've reminded me and the new version is attached to the original post.
Post by Jan_K »
Have added it to the library that will be updated next month. :)
viewtopic.php?f=23&t=4528
Pidea
Post by Pidea »
Excellent, glad to give a tiny amount back :D
dave77
Post by dave77 »
Hi All
Really new to freestyler but have these light so wanted to add the file to my fixture list, Only problem is everytime I try and import it I get the following error "input past end of file" does anyone have any ideas?
Thanks in advance
Dave
Pidea
Post by Pidea »
Sounds to me like theres a problem with file. I think the last updatevto thebforum screwed up some of the forum attachments. If you PM you email address I'll email you file. I'll update it later on the forum when I get home.
All files working now you should be able to re-download fine
