Iphone/Ipad App Topic is solved
coley65
Iphone/Ipad App
Post by coley65 »
Is this project now finished development?
Coley
coley65
Re: Iphone/Ipad App
Post by coley65 »
Can somebody answer this?
Coley
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Iphone/Ipad App
Post by Mattotone »
It is in its complete state, but it not to say he may release new features as in app purchases.
what is it your needing???
coley65
Re: Iphone/Ipad App
Post by coley65 »
Thanks for the reply yes it does work 100% for what I need it for however I find the sequence/group/ buttons too small on the ipad.
Also I would just like to say thanks for this great solution.
Regards
Coley
biggus
Re: Iphone/Ipad App
Post by biggus »
First of all thanks for creating a great app for the IOS platform, I've used it many times on a live gig, however Its been a while since this post was updated and I'm wondering if there any developments or planned developments for this app? the Windows app appears to be having lots of new developments at the moment and it be great if the IOS app could catch up or further improve on the windows one? :fs:
Re: Iphone/Ipad App
Contact MMAX the Moderator he is the Developer of the iOS app if he doesn't respond to peoples request then one of us pending funds! May release an iOS app.
Re: Iphone/Ipad App
Post by Mattotone »
Id consider the ios app dead and awaiting some one new to create one.
dmxlighting
FreeStyler Version: beta
Re: Iphone/Ipad App
Post by dmxlighting »
in a way I already showed everyone how they can develop an iOS app themselves by using Touch OSC.
You can totally customise it to do whatever you want - Its basically just a midi controller for iPad/iphone.
I use it all the time and its brilliant. I did download the official app a long time ago and at the time it was the only thing that really worked but it was not much use to me as it had very limited 'showtime' control.
Touch OSC can be used to control in much the same way a BFC2000 can be used only far better!
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Iphone/Ipad App
Post by buttza »
I use the Touch OSC app.
Can you share some of your layout files at all? That would be great.
Cheers.
Robert.
buttza
Re: Iphone/Ipad App
Post by buttza »
I have just realised that the Midi.fms file I included will no longer work with the FSDMX 3.5.6 so I am in the process of updating it. I will push the update through by Friday. Thanks. :fs:
Return to “iOS (iPhone & iPad)”
