Chauvet Insignia - Barrel Roll Topic is solved
gothambeat
Post by gothambeat »
I have an old fixture that I can't seem to get working correctly in FS. There are 4 issues:
1) The fixture has a barrel roller that has 2 channels
Channel 4 is the barrel orientation (0' - 180');
Channel 5 is the barrel rotation (0-120 360' clockwise rotation speed; 121-36 STOP; 137 - 245 ccw rotate speed; 246 - 255 STOP)
2) The fixture has a GOBO wheel on channel 2 with 16 gobos. They are defined between settings 0 and 127. The problem is 127 through 256 is a gobo wheel spin speed (slow->fast)
3) The fixture has a COLOR wheel on channel 3 with 12 colors that are defined between setting 0 and 127. The problem is 127 through 256 is a color wheel spin speed (slow->fast))
4) The fixture has what they call STROBE speed but it is basically a gobo and color wheel bounce effect with the following settings: 0-15 (GOBO Stopped); 16-91 (Adjacent gobo strobe slow->fast); 92-135 (Adjacent color strobe slow->fast); 136-195 (Adjacent COLOR & GOBO strobe slow->fast); 196-255 (Gobo Bounce slow->fast)
Has anyone encountered this type of fixture that mixes functions on the channels? Any help would be greatly appreciated.
Nathanrs93
FreeStyler Version: None
Re: Chauvet Insignia - Barrel Roll
Post by Nathanrs93 »
Hey,
Do you have a half completed fixture or anything like that at all that you can upload? I'll see if I can have a look for you and correct the problems :)
Best Regards,
Nathan
Forum Moderator
gothambeat
I exported it. I'm not sure if all the graphics come through but here is the file
Insignia barrel.pff
(67.8 KiB) Downloaded 109 times
Nathanrs93
Hey,
Thanks. I'll have a look and see if I can't fix your problems for you :)
Best Regards,
Nathan
Forum Moderator
Post by Jan_K »
Here are the DMX table for it.
http://www.chauvetlighting.com/products ... ug-145.pdf
Nathanrs93
Hey,
Cheers Jan_k. I'm afraid I can't finish this fixture due to my laptop dying on me and I'm awaiting my new one before I can do anything again unfortunately.
Regards,
Nathan
Post by Jan_K »
Hej again.
It looks like it's an old fixture created before value check.
Some values are 256, max is 255.
There is a new one in this library viewtopic.php?f=23&t=4528
Actually it is this one. (Then you don't have to download the whole lib. )
Chauvet_Insignia.pff
(67.44 KiB) Downloaded 102 times
