FS hangs when selecting fixtures Topic is solved
Mal
Post by Mal »
Dear Freestylers,
Newbie Mal here, getting stuck before i even get to the first hurdle.
As soon as i try and select any fixture the CPU goes to 100% and then nothing else ever happens.
I've left it overnight and no change - just click the close button, FS shows as not responding, etc
I've tried to download the "quick fix" on the index page (3.5.2 already installed), but the link to the rar file seems to be broken.
Is the phenomenon i'm seeing related to this?
I'm currently using the virtual interface until my dongle arrives.
So what am i doing wrong?
Cheers,
Mal
Nathanrs93
FreeStyler Version: None
Re: FS hangs when selecting fixtures
Post by Nathanrs93 »
Mal wrote:Dear Freestylers,
Cheers,
Mal
Hey,
I have told the Admins about the broken link on the front page like you say and they are sorting it. What are your specs of the laptop/pc your using?
Mal
Post by Mal »
Thanks for the quick reply. So it may be the rar/link that fixes it then.
It's a plain XP laptop, twin core Intel 2.5Ghz dell with 2Gb Ram.
Cheers,
Mal
Nathanrs93
Mal wrote:Hi,
Cheers,
Mal
Hey Mal,
The link could do as it's fixed a lot of problems for people having problems of it freezing etc, but you'd have to try it and find out. But looking at your specs it's not a bad laptop so it should be able to run it with out any stress :?
We'll see if we can't get you working and unleashing them beams again ;)
Best Regards,
Nathan
Forum Moderator
Mal
Post by Mal »
Thanks Nathan.
Is there another location i can get it from?
In fact, it will be unleashing those beams for the first time....
Mal
Nathanrs93
Mal wrote:Thanks Nathan.
Mal
I don't believe there is another place unfortunately so I think it's just a waiting game. I'm shocked, it seemed liked your had done it before and was a pro ;) Well I wish you luck :)
Best Regards,
Nathan
Forum Moderator
Mal
Post by Mal »
So i can get started (deadline approaching and fixtures not even arrived yet), i may try a slightly earlier version. Do they all need this patch, or should any recent version be ok?
Mal
Nathanrs93
Mal,
I believe it's just version 3.5.2 that needs the patch as it was having a few problems from different people, including myself. If you try the other versions I believe they should all be fine, however if you do find a problem or experience a problem then please submit it in BT. Thanks
Best Regards,
Nathan
Forum Moderator
Mal
Post by Mal »
hi,
I've now got 2.96j installed as it seems to be the newest version available.
Without trawling though the change history, can i assume that this is basically the same as 3.5.2?
The UI is essentially the same and any "data" i produce with it can be used by later versions?
Might i also humbly suggest that the forum home page doesn't give a link to 3.5.2 as the latest stable version? When it isn't, and needs a patch that can't be downloaded?
Perhaps the previous version might be more suitable?
Cheers,
Mal
Nathanrs93
Hi Mal,
There is a stable verision for 3.5.2 at the top of the page, however the patch came after due to a small error for people that were experincing problems. Please be patience as I'm such you are aware the people that do this have 9 to 5 jobs and are doing this for free.
I'll have a word with the Admins to see if we can't get the problem sorted ASAP.
Best Regards,
Nathan
Forum Moderator
EDIT
May I also recomend that if you are not doing anything major and it's causing your CPU to go 100%, that you sumbit a bug report about this so the developers can sort it. Thanks
Submit bug report here
A new release is coming so the rar file is not needed please bear with us.
Mal
Post by Mal »
<bearing> :)
Mal
Post by Mal »
My apologies, i thought this was issue for all 3.5.2. users.
Anyway, bug report made if you think it can help.
Mal
