Involight scl250 s/6 fixture
Norberto80
Post by Norberto80 »
involight scl250s/6
Edit, Nathan
Please make sure you upload the file as .pff. Thanks
SCL250S6.pff
(27.06 KiB) Downloaded 36 times
Re: Involight scl250 s/6 fixture
Post by Jan_K »
Hej Norberto80
I tried to inport the fixture but it came out with an picture error.
Can you try to export it again and upload the file again.
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Jan_K wrote:Hej Norberto80
That could be my fault as it was a .zip file and I exported it as a .pff.
Norberto80
Involight scl250 s/6 fixture only .fxt
Works with Freestyler version: 3.5
Only .fxt format is.
SCL250S6.zip
(421 Bytes) Downloaded 33 times
Norberto80
Involight scl250 s/6 own gobo images
I'm sorry! missed it earlier.
The following compressed files are copied to the "gobo" directory ....
"picture" problem solved
Individual Gobos.zip
(11.19 KiB) Downloaded 30 times
Post by Jan_K »
Here as pff
Involight_SCL250S6_6ch.pff
(17.73 KiB) Downloaded 41 times
