Hi all,
Im trying to set up a connection between ableton live and freestyler via loopbe.
So that if I play midi notes in ableton, sequences in freestyler are triggered
I made sure that ableton is sending the midi via loopbe1, and now trying freestyler to receive it.
But here's the problem, when I select loopbe in external control - midi control,
It won't let me change the notes, so I can't configure the notes which trigger the sequence. I tried pressing the keys in ableton corresponding to the correct notes, but nothing happened. Do you have any ideas what im doing wrong?
Thanks in advance, Vurrnn
midi from ableton live to freestyler setup
Vurrnn
- FreeStyler Version: 3.05
