Get The Freetyler Remote LITE App Here!
OLD ANDROID FORUM
Locked
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
Auto Connection No IP address required, Locates and Connects Automatically. No External Server.
Common Buttons Quick access to the common buttons, Blackout, Favourite, Freeze, Tap Sync, Release All, Manual Step (£) and Fog
Six Cue Toggle Buttons Toggle play back of the top six cues. Upgrade to 20 (£)
Six Override Buttons Toggle the first six overrides. Upgrade to 20 (£)
Auto Labels Buttons and overrides names are fetched directly from FS.
Whats missing from the free version?
Full Sequence control toggle cues 1 - 20 with speed control, Tap Sync, Manual.
Full Override Access Control all overrides, and override pages
Full Cue Lists Control all overrides, and override pages
Full Fixture Control Control every fixtures attributes, PanTilt/Colour/Gobo etc
Master Intensity Fade IN, Fade Out, 100%, 0%
Reason: Anounce for 14 days
Re: Android Remote LITE
Post by Mattotone »
DJDaveSA
FreeStyler Version: 3.6
Post by DJDaveSA »
Hey Mat
I have downloaded the new app and it worked great the first time i tried it. Now it wont connect.
i have restarted both the pc and the tablet and nothing. When i input the ip address manually it still does not connect. Anything else i can try? Let me know if you need anyone to beta test the pro version. Also i don't control freestyler with the cues but i do use the cuelist buttons. any chance of options to change what the app controls?
Post by Mattotone »
Strange, if it does not connect via IP address i would suggest that FS is not reachable. Firewall, Wifi off?
The developers console is showing no crash reports. what screen / error messages if any?
The software supports overrides and individual cues. I will look into the tcp/ip documentation to add cuelist buttons to the pro version.
DJDaveSA
Post by DJDaveSA »
Hi Matt
I tried the app again and noticed that the externally controlled icon in freestyler does come on when i tried to connect. When i click on it and say disconnect all, then restart the app it does connect perfectly. Not sure if the issue is on the server side? Have got a gigs this weekend an will test. Otherwise awesome work will definitely purchase the full pro version.
Post by Mattotone »
Ahh yes. I have had this myself. The same problem exists with the ios app. I believe this to be server side as it only has one socket and doesn't allow reconnection.
hi i alsp have had this issue..
but now i now why this happins.
i also have a other issue..
thats if i Disconect the connection on FS.
the App keeps running and says its connected.
If i press HOME button on the phone the app stays running.
and if i press BACK then the App shutsdown..
Post by Mattotone »
By design the app is to maintain the connection whilst paused (home) button this is to allow you to read a text take a call etc. Back button disconnects and closes. I can add a disconnect button if this isn't easy to find by users.
Also it appears that fs doesn't disconnect properly so the apo thinks its connected untill it fails to send information to fs. Then it will show as disconnected. How often is the app failing to connect? Is this after closing fs without exiting the app by the back button? I have some updated code to addresses some reconnection errors. Unfortunately nothing to reset Fs connection or detect if the connection was not closed properly.
Post by Mattotone »
New update added to playStore.
Upgrades to the connection manager.
Background connection bug fixed.
Bug fix when cancelling the autoConnect service.
DJDaveSA
Post by DJDaveSA »
Tested and all bugs fixed. Great work.
Yes seems to work ok now.
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
Post by Crrispy »
Hello,
Just tried it with an Archos tablet, connects and works fine. But... in 95% of the places where I could use this, I'll have no wifi access/router... so what?..
Thanks.
Post by Mattotone »
You could either buy a cheap cable router and take that with you to create a wifi access point.
Alternatively create a adhoc network in windows, if your computer doesn't have wifi you can get a cheap usb dongle too
The cable router will be the simplest option.
Crrispy
Bug Zapper...
Post by Crrispy »
Yup, thanks, think I have a WRT 54G still lying around.. have to check... but 1 more equipment to transport/plug.. Bluetooth would be nice :roll:
Post by Mattotone »
Freestyler doesn't support Bluetooth so unable to use that.
You can use adHock wifi to doaway with the router.
chrisnet
FreeStyler Version: 3.3.2
Re: Get The Freetyler Remote LITE App Here!
Post by chrisnet »
I love the idea! but I can not control any of the lights.
I can log in to Freestyler just fine but I can not control anything.
In the "fixture Control" no fixture's show up just "Lamp" and "PanTilt"
none of my override buttons or cues show up
Is there something that I am missing with this app? "I can control Freestyler in another app"
Post by Mattotone »
Whats the other app?
Ensure you have latest beta from this forum, Fixtures are currently just groups so make sure you have them created. FS creates these automatically when you add fixtures.
Also only "lamp" and PanTilt? Iv double checked but my app doesnt have any reference to "Lamp"
Unless you have downloaded this Freestyler DMX Remote ALPHA 2.5.1 which is wayyyyyyy old, and removed from the playstore.
chrisnet
Post by chrisnet »
And yes it is Freestyler DMX Remote ALPHA 2.5.1 and I did just download it so I will look for the newer version and get back to you Thanks
chrisnet
Post by chrisnet »
I went ahead and paid for Android Remote Pro and I have to say it has everything I need! I am using it for my DIY landscaping LED's and my DIY home entertainment room LED's.
Next up I would like to build a switcher that I could use to switch from Freestyler "computer" for holiday use to a DIY touch screen wall controller for everyday use. Or maybe have the wall controller link to freestyler!!
Post by Mattotone »
Thanks for the purchase,Glad it is able to do what your needing.
:fs:
Locked
Return to “Android.old”
