Bez Files Topic is solved
Bryzer
Bez Files
Post by Bryzer »
I figured out you are able to save costum made shapes but is there any way you could delete them from inside the program? The only way I've found out is to go /freestyler/chases/ and delete them manually. If I do so, they will still be listed inside the shape menu in Freestyler. This is a little frustating while you're performing live because you don't want to restart the program but you also do want to keep things nice and clear.
It is possible to create sequence's out of those .bez files right, or use them somehow in the cue menu? Like instead of creating every step in a cue you can just use the .bez file's (shapes).
Thanks for reading!
Re: Bez Files
Post by Jan_K »
Hej Bryzer.
It is the only way to delete the shapes.
How to use them.
Have a look here http://www.freestylersupport.com/wiki/t ... e_tutorial
Bryzer
Re: Bez Files
Post by Bryzer »
Thanks Jan.
I only don't understand how to use them in the cue list?
Re: Bez Files
Post by Jan_K »
The easiest way is to use the submaster function.
Clear the whole cue.
Insert all the sequences you have created with shapes.
Save this cue.
Clear the cue again.
In Submarster add the cue you saved with shapes.
It is now possible to have a cue running with one shape.
The shape sequence can now be shifted with the submaster.
Have a look here http://www.freestylersupport.com/wiki/t ... playground
Bryzer
Re: Bez Files
Post by Bryzer »
Thanks!
