AccuSpot 575 Topic is solved
hockey101
AccuSpot 575
Post by hockey101 »
Hello,
I would appreciate if someone could take a look at my American DJ AccuSpot 575 fixture file. I made one a long time ago and it never did work properly. The rotating gobos would never rotate, dimmer never worked properly, among other issues. So I remade a file from scratch. These 575's are in a hockey arena, used for the opening light show and team entrance. I intend to take the file to the arena within the next day or two to try it out, so it would be great if someone could make a few edits, as I am sure I will arrive there and half the functions will not work properly lol!!
Here's the online manual: http://www.americandj.com/pdffiles/accu ... manual.pdf
Fixture should be attached to this post.
NOTE:
I made the "gobo rotate" function as its own gobo channel because it would not work when I simply put the correct channel number under "gobo rot 1:" ...if you know what I mean :?
Thank you very much for any help.
