Submaster intensity external control problem
MagicJohansson
FreeStyler Version: 3.6.3
I Use FreeStyler for: Band
Post by MagicJohansson »
Hi guys
I am getting there quite fast with FS already, quite a piece of software :-)
I have one problem though :
I have set up my LED's for different colors by making 1 step sequences for each color, adding them one and one to a cue and connecting that cue to submasters. The submaster intensity channels is then controlled by a fader on my BCF2000's. This works fine, fading the LED's up from 0 to full with he fader on the BCF2000, but ONLY if I have the Submaster-window open !!! If I don't open the submaster window whet happens is that when I start moving the fader the lights come on, proportional to the fader but when I stop moving it at, let's say 20% after about half a second or so it jumps to full intensity (the LED, not the fader). If I then grab the fader and move it the lights again follow the fader but when I stop moving it, BANG, ip to 100% again.
Then I open the submaster-window and it works again.
What am I missing here, or is this the way it works for some reason ?
Thank You
Magnus
Re: Submaster intensity external control problem
i totaly agree with you and last week i created a issue report about it.
as i use TUI2 and have the submasters on there so i dont need to open it..
so this will be fixed in hope in the next beta/Public release..
EDIT it just got a Mail from the devolper :
For the submasters to work the window must be open otherwise it won't work.
So if you like to use the SM the Windows just needs to be open.
MagicJohansson
Ok, thank You for the info, then I just have to open the window, no big problem.
Magnus
