First, I'm using Chauvet Intimidator LED Spot 150's.
I've followed the Submaster tutorial, and I'm having a problem making the lamp turn on (or the shutter open, however you prefer) when I play back sequences, either directly from the submasters or from the cue buttons.
The shutter and strobe are on the same channel (channel 7), and the dimmer is on channel 8. There is no lamp channel for the fixture.
Any tips or suggestions?
Thanks,
Tom
Help: Intimidator LED "Lamp on" problem with Submasters?
- Just started using FS
- Spirit
- FreeStyler Version: 3.5.9
Re: Help: Intimidator LED "Lamp on" problem with Submasters?
hi
the PDF and Fixture file seems correct IF you use the 11ch mode..
If you use the 6ch mode its a other story..
And LAMP ON and shutter are 2 differnt things.
As a HID light have a Special LAMP ON Channel+Value
the Shutter = Shutter + Dimmer + Strobe all in one.
only you use diffent channels for dimmer and Shutter+Strobe
/Spirit
/Spirit
Thanks, Spirit...
Do you know what might stop light coming out of the fixtures when played back as submasters (or as cue lists made from submasters)?
Thanks,
Tom
Thanks,
Tom
Spirit,
Never mind... somehow it's working correctly now. Thanks much!
