Gamepad Control Issues
djwzak
DJ
FreeStyler Version: 3.4.8
Post by djwzak »
Hi people,
I have a cheap Playstation imitation USB gamepad, the left analog joystick works fine with pan/tilt, the arrow buttons also work fine, I also have assigned the buttons to color,gobo but I have the following problems:
1. When I press the ANALOG key to deactivate analog function in joystick, then I cannot activate it back unless I press "Toggle" and/or "Joystick" shortcuts from the keyboard.
2. The previous problem also happens after I press a key (rectangle, triangle, circle or X) to change color or gobo.
Thank you for your time.
:fs:
