Hey,
I'm trying to program a little mini X factor scene type of thing, where the lights just move around the room on and off etc. I was wondering if anyone had tried this and had any luck? Got any tips? I keep trying to do it but something is always seems to go wrong.
I'm hoping to program it with 2 moving heads (maybe 5) and 4 scanners, to the best I can. Anyone done it?
//Nathan
X Factor Scene
Nathanrs93
- FreeStyler Version: None
- djSupport
Re: X Factor Scene
Create 2 sequences... one for movement of all the lights and then one that just operates the on and off of the beam...
- djSupport
Re: X Factor Scene
Then enable 'cue multiselect' in the options and run both at the same time
- djSupport
Re: X Factor Scene
The benefit then is when your light moves from x - y using the 'fade' speed but you have an independantly controllable fade speed on the light if that makes sense!
Nathanrs93
Re: X Factor Scene
Explain...I don't quite understanddjSupport wrote:The benefit then is when your light moves from x - y using the 'fade' speed but you have an independantly controllable fade speed on the light if that makes sense!
//Nathan
EDIT: I'm planning on doing this by submasters or cuelist so that I can just flick it on and off when I need to.
- djSupport
Re: X Factor Scene
Lets say your light moves from left to right thats two steps and you want to control the speed so you set them to fade! step 1 you just program the light so its pointing to the left you set no other options (So everything is 'off' and the movement is set as 'fade;) then on your second step you do the same but move the light to its right, now when creating this you can set the fade and scene time as you need to control the speed at which it goes from left to right yes?
but how do you make your fixtures flash light in a pattern that is independent of the speed at which it moves?
i.e. if you program it while programming the movement your restricting the speed to that of how fast you want the light to move!
So you create a new sequence and lets say have the light flash on and off like a strobe so create two steps one step on one step off but set these as snap so its not fading but when you play it it will flash at the speed of the scene time. so now if you run them both in the cue at the same time you can control the speed of the movement and independently control the speed of the light flashing!
I look at my text and it looks complicated how I've said it but if you paid me petrol lol I could be in chesterfield within an hour and a half!
The effect would look better with more lights imagine 8 moving heads that you have programmed to randomly move about panning and tilting, every pan and tilt could have the light coming on and off but if you do the light part separately you could have each light light up for a split second and then move onto the next a bit like a chase and because its independent of the movement you could have that light pattern fast slow or whatever but have the movement at a set constant speed
- djSupport
Re: X Factor Scene
I think the submasters do the same thing but thats how you do it... im not a submasters expert
Nathanrs93
Re: X Factor Scene
Thanks djsupport.
I understand it alot better now
I'm gonna probably have to miss it on this event as I've not really got the fixtures to make it work properly. But I'll have a play around and see what I can come up with, with the fixtures I have available to me
//Nathan
//Nathan
- djSupport
Re: X Factor Scene
Have fun!
