when i make a sequence with strobe i can play it. but after i play this the strobe function keeps on going in every cue i play. even in the one's where there is no strobe programmed. who can help me with this problem?
i have this problem at home but also in a pub where i use freestyler on a other computer.
strobe Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: strobe
Hi
How do you playback your Strobe sequence..
Cuelist buttons?
And there's a Arrow "RESTORE VALUE" if you enable this the Strobe Sequence should stop.
Cuelist buttons?
djpaulb
Re: strobe
I play the sequence by pushing the play button in the cue list. If i push a New One after the strobe sequence it starts to play but the lights stay flashing. And whatever sequence i play after this stays flashing.
Nathanrs93
- FreeStyler Version: None
Re: strobe
You don't have multi cue selected in options, do you?
djpaulb
Re: strobe
no i dont have multi cue selected.
i tried to use the arrow with restore value but than the lamp is off in the next sequence i play.
so i still dont know whats the problem.
