Fixture DTS XR9 Topic is solved
Conty
Fixture DTS XR9
I need a freestyle fixture for DTS XR9 Spot moving head, I can not make it alone and I would like if someone has done to help me please I would be grateful
thanks
thanks
Nathanrs93
- FreeStyler Version: None
Re: Fixture DTS XR9
Hi Conty,
If post the manual here, then I'm such some nice person will help you out and make you the file you need.
//Nathan
//Nathan
Conty
Nathanrs93
Re: Fixture DTS XR9
Hi Conty,
I've had ago for you and the was a few things I was unsure about, but unfortunately I wasn't able to upload it here to the forum as an error came up when I tried to save it. I'll have another go for you when I have a spare few minutes, but if someone does it before me then fair enough.
//Nathan
//Nathan
Conty
Re: Fixture DTS XR9
if you did something for me we can talk on messenger ( mita112001 is my id)if you could not upload it here give it me on messenger
Conty
Re: Fixture DTS XR9
You can upload something here is you click on POSTREPLY and under Save draft , previer and submit you have Optinons and Upload attachment
Nathanrs93
Re: Fixture DTS XR9
Hi Conty,
You totally missed what I was trying to say
I tried to save the fixture file and export it up here for someone to have a look at to see if everything was right, however it came up with an error when I tried to save it. So when this happened I actually lost the file and it didn't save it...
I will have another go when I get a spare few minutes as I'm busy at the moment programming things for an up coming event. But if someone does it quicker as I'm still learning and not the fastest of people then fair enough.
Any questions, PM me
//Nathan
//Nathan
kristoffer
Re: Fixture DTS XR9
Hello,
Here is a fixture file. It's not tested but should be working. Try it and let me know if anything is incorrect.
XR 9 Spot (18ch).pff- Ver 1.0 (Not tested)
- (221.9 KiB) Downloaded 144 times
Nathanrs93
Re: Fixture DTS XR9
You had to beat me to it didn't you, kristofferkristoffer wrote:Hello,
kristoffer
Re: Fixture DTS XR9
Sitting at work and im booored! So I needed something to do. Sorry!
Nathanrs93
Re: Fixture DTS XR9
I'll leave you with it anyway, I'm not that good and quick with fixture creator yetkristoffer wrote:Sitting at work and im booored! So I needed something to do. Sorry!
Conty
Re: Fixture DTS XR9
i'm in bed but i can stay i have to try the fixture i will tell you if is working in 15 minutes
Conty
Re: Fixture DTS XR9
is not working propretly the colors are not like in the freestyler and the gobo weel is not working good and the light is pulsing (not strobe)...i think i need for 26 channals
Conty
Re: Fixture DTS XR9
if you want i will install team viewer and you wil make the changes and i will tell tou wath happens..please because saturday i will have an event...please
kristoffer
Re: Fixture DTS XR9
First of all, are you 100% sure that you have set the fixture into 18 channel mode instead of 26? Otherwise this fixture won't work.
kristoffer
Re: Fixture DTS XR9
Yes, now im 100% sure that you have set up your fixture for 26-ch mode. You have to switch to 18 otherwise this profile will now work. If you are not shure how to do it, just take a look in the manual.Conty wrote:from the first gobo weel i change color:(
Conty
Re: Fixture DTS XR9
i have to set the moving heads into 18 channals mode??or from the DMX?
Conty
Re: Fixture DTS XR9
you where right the moving heads were in 26 ch mode?
i have 2 questions: how can i set aufotocus mode and what is the diference betwen 18 ch mode and 26 ch mode?
thank you verry much
Nathanrs93
Re: Fixture DTS XR9
Auto focus mode should be either on the moving head or you might be able to do it on freestyler. The difference between 18ch and 26ch mode is the fact that you'll have more individual control of the head in 26ch, were as 18ch most things will be doubled up on one channel.Conty wrote:you where right the moving heads were in 26 ch mode?
//Nathan
Conty
Re: Fixture DTS XR9
but i want that auto focus to be made automatically,where i have to set that?
if you can please do me for 26 channals mode,please?
