I have recently bouhgt a touchscreen monitor for the use with freestyler.
Now the problem is, when i select a fixture i can use all the attributes exept the color wheel.
i have also reported this as a bug to Raph.
is there maybe somebody with the same problem.
touchscreen Topic is solved
- djSupport
Re: touchscreen
how much was your touchscreen? are they cheap??
TTlight
Re: touchscreen
It depends what do you want.DJ Support wrote:how much was your touchscreen? are they cheap??
Know i've got a 15 inch USB supported screen from IBM? it comes around 450 Euro.
- djSupport
Re: touchscreen
pah thats a fortune!!
