Freestyler 351 and Digital Enlightment Interface BUG
MAAC
Just started using FS
Post by MAAC »
Hi
Just wanted to let you know that Freestyler 351 breaks Digital-Interface compatibility.
On version 351 the usb and dmx out led flicker and it doesn´t work.
Version 348 works ok on Win7 and Vista x64
Please correct
Thank You
fktronik
Re: Freestyler 351 and Digital Enlightment Interface BUG
Post by fktronik »
Have the same problem,
Interface works with DMX control with no problems.
in version 3.4.6 is the Fx run 5 interface, the software can
not find to test it.
mfg.fktronik
Flip
FreeStyler Version: 3.3.6
Post by Flip »
I got the same problem here. I'm having an event on friday and updated Freestyler. But I shouldn't have done this. I got the same LED flickering Problems. A roll-back to 3.4.8 helped
It should be fixed now with latest download...
