help fixture laserworld cs-1000 rgb Topic is solved
r.de.heus
FreeStyler Version: 3.5.1
Post by r.de.heus »
hi guys im just new and working freestyler now for few days i have 4 HQpower space250 and 6 martin roboscan 218 running on freestyler now. yesterday i bought a laserworld cs-1000rgb but i cant fint any fixture and i have no clue what im doing in the creator :? can somebody help me to create one i really need it sunday for a church concert. great thanxx Robert
Nathanrs93
FreeStyler Version: None
Re: help fixture laserworld cs-1000 rgb
Post by Nathanrs93 »
Do you have the manual by any chance? Then we can see what we the DMX values are that we need to do it. :)
r.de.heus
Post by r.de.heus »
Only online i found something if i google laserworld cs-1000rgb manual
r.de.heus
Post by r.de.heus »
r.de.heus
Post by r.de.heus »
Hey is it really thad i need al 200 paterns add one bij one from thad list of gobos. I now have connect my laser to dmx and start at ch 1 gobo see the laser pattern and go look in the list to find a look a like gobo and then 2. Its taking ages on this way and lot of patterns i cant find in the gobo list
Nathanrs93
i've had a go for you but unfortunately i can't complete the fixture, because i don't know the patterns for the laser as i don't have it. sorry. however someone else might be able to do it for you.
//nathan
Post by Jan_K »
r.de.heus
Post by r.de.heus »
Hey jan_k thanx i think i get it. So i need to go tru al the patterns and make pictures and add them in the list and then put them in the gobo list.
Nathanrs93
that's right r.de.heus. It is annoying and a long process but it works out better for your self (and others if you upload it after). good luck.
//nathan
andreamocce
FreeStyler Version: 3.5.2
Post by andreamocce »
Hi did you make a fixture for cs-1000 rgb ?
Nathanrs93
I don't believe there is a fixture for Laserworld cs-1000 RGB as I couldn't finish the one I had because of not having the gobos or things like that. Then the file corrupt itself, unfortunately.
hi maby this one will work but i''m not sure.
TheAfrojack
FreeStyler Version: X2
Post by TheAfrojack »
Have you already made the fixture for freestyler? I would like to have it!
Post by Jan_K »
I think there is a fixture for the cs-1000 rgb in the FreeStyler_Fixture_Lib.zip
viewtopic.php?f=23&t=4528
