Hi guys... pulling my hair out here:
I have two Chauvet Intimidator 300 scanners. When using the master fadeout, the scanners will fade to zero but then jump back to 100% intensity after the fade out. Very annoying.
What's going on here and how can I prevent this?
Thanks!
Scanner resets to full intensity after master fade Topic is solved
CaptainBetty
Re: Scanner resets to full intensity after master fade
Probably posted this in the wrong forum, but I've attached my fixture file for my intimidator 300
IntimidatorScan300.pff- (176.56 KiB) Downloaded 46 times
