Hello-
I am looking to use a program (hopefully Freestyler) to do the same exact sequence, which I will setup, for a single song. I want to be able to sync the two together so the sequence and song go at the same times, and right times.
Is this possible? I have other programs like VDJ incase I need to link the two together.
Thanks,
Matt
Setup an entire sequence to a single song
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
Re: Setup an entire sequence to a single song
Hi, have a look here -
http://www.freestylersupport.com/wiki/create_sequence
The sequence creator should be able to do all this for you. I have not actually done a whole song however I have been studying how to cue off songs and if you get the timing right (the sequence creator can be programmed to milliseconds) this will probably do the job for you.
The other good thing is that you can go back and edit your sequence i.e. all aspects including the timing of cues to suit. Hope this helps maybe a little.
Mac
www.mclite.co.uk
www.mclite.co.uk
- FreeStyler Version: 3.6
Hi djmattw
What software do you DJ with? In virtual DJ you can download the SBDJ Freestyler plugin you can create cue points and send commands to freestyler. It takes a bit of setting up but works great.
