Hi All,
I wondered if anyone else has come up with this problem please....??
I have set up a couple of scenes on the cuelist buttons to test between static and moving scenes on the cue list buttons. These are not the finished articles as I am just testing just now before building the finished scenes. I have tried to build the moving scenes by selecting submaster cues, customising them and then saving them to a cue list button. The static scenes seem OK i.e. switch on and off as necessary via the cue list buttons however there seems to be an issue with the moving scenes. By moving scenes I add the moving heads etc. It seems when I do this and have the cue list set to 'Loop all sequences' all the fixtures switch off when I deselect the cue list button. Unfortunately 'Loop all sequences' does not play the scene as I want it so I untick this option but when I have a moving head engaged and then deselect the cue list button the middle PAR on the rear truss does not switch off. On checking the output it is sat on 255 and I can only switch it off manually. I have tried a number of different scenes and it is always the same when deselecting i.e. the middle truss PAR continues to operate but only when I introduce the moving heads to the cue. The rest of the fixtures fade out as per the scene I programmed.
Just wondering if anyone else has this problem at all please.
Rgds Mac
Same Fixture Staying On
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
