I'm running the lastest Version of FS on Windows XP (32 bit, 2,6Ghz Core 2Duo Laptop, 1GB Ram) with a 22" ELO Touchscreen (connected via USB)
If I enable the UI2, the Touch response is very bad. Some buttons react not at all and others only with a huge delay. So you aren't able to use the flash Buttons at the right time, for example.
The "normal, grey" touch view works excellent, without any problems! It's only with the UI2 View and I have no idea why...
I also tried it on another PC (also windows XP), with the same results.
thanks for your help,
Timo
