I picked up some of these modules on ebay:
http://www.ebay.co.uk/itm/251104955206? ... 1439.l2649
They came with no manual. Has anyone used them with any sucsess, There are no switches on them so no idea how you set their address??
LED RGB Light Lamp 3 Channel 3CH DMX Controller
Jimster
- FreeStyler Version: 3.4.6
- I Use FreeStyler for: Film
edwinb
Re: LED RGB Light Lamp 3 Channel 3CH DMX Controller
yes they work fine and are great value
address is programmed to 1,2,3 ( r,g,b)
to change addressing you need a programming control unit connected to a pc
regards
edwin
PS
you could try ShenZhen Leynew Technology Co.,Ltd
http://www.leynew.com
ADD:Room 402-403, Jinhu yayuan, Luozu Road, Shiyan Town, Bao'an District, Shenzhen City, Guangdong,China
TEL:+86-0755-29686890 / 29686239 FAX:+86-0755-29686158 E-mail:sales@leynew.com
Model: LN-DMXID-EDITOR
but I havn't tried this myself
regards
edwin
PS
Nathanrs93
- FreeStyler Version: None
Hey
Quick question in regards to these. What does it mean when you say "programming control unit"?? Thinking of getting some, but want to change the address on them if possible. Then I don't have to spend a lot of money on other controllers if this works.
Thanks,
Nathan
Thanks,
Nathan
- djSupport
This was brought up on the facebook page, you need a seperate device to change the addressing of the fixture...
