I have just purchased a ultraDMX RDM Pro interface from DMXKing.com to use with freestyler. I am using some EVL proscanner 150's
http://www.evl-design.com/evl150250scanner.html.
Now, when i run freestyler and go to the fixture list and select EVL the only fixtures are EVL Minispot 150.
If the fixture I am using is not listed then do I have to create a fixture using fixture creator and if so will I need to download fixture creator or is it included in freestyler somewhere?
Paul
EVL Fixtures Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: EVL Fixtures
yes i also lookt at the libary jan_k made and the only fixture from EVL is minispot.
so you need to create the fixture your self.
And yes fixture creator is included with FS, so default C:/Freestyler and there you can find Fixture creator.
and there you can find ALLOT of info about FC http://www.freestylersupport.com/wiki/fixture_creator
- FreeStyler Version: Beta
