Magic 3d not respnding to freestyler
redvandan
Post by redvandan »
Ok I have exausted all my resorces
i have tried to install freestyler alone, with the regular 3d, with the beta 3d, with dongle, with out, ive tried to add fixtures, make fixtures, uninstall/install, etc etc etc. Nothing works i can create and do every thing i should be able to in the programs it just doesnt show up ive checked outputs they seem ok ????ahhhhhhhhhhhhhhhhh!!!!!!!!!! :x help please
Re: Magic 3d not respnding to freestyler
hi EV works ok the only issue you can have is that the Dimmer or RGB channels doesnt work.
but to solve this try this link. viewtopic.php?f=56&t=4526
redvandan
Post by redvandan »
I did all of that a couple of times even and it didn't work. Now it magicly started working thanks for the virtual karma wave i guess thats all it needed :lol:
redvandan
Post by redvandan »
I guess the only thing I did different this time is added the fixtures in the user mode. not sure if that made the difference.
