Submasters
Nathanrs93
FreeStyler Version: None
Submasters
Post by Nathanrs93 »
I am wanting to use submasters for my next show that I do, but don't have a clue about them or where to start. If anyone could give me some tips and help me out then that would be great. :)
Thanks.
CaptainBetty
Re: Submasters
Post by CaptainBetty »
I'd strongly suggest reading the Frestyler Wiki on submasters here: http://www.freestylersupport.com/wiki/c ... d_tutorial
I think of the submaster section as a mixer for various cue lists. I'll create scenes of just colors and add them all to a cue list. Then another cue list of scenes of just dimmer chases. Another cue list for scanner pan/tilt moves; another for scanner dimmer chases.
once you separate all those attributes, you can then mix and match those in the submaster panel. So you can choose a color scene, and a dimmer chase.
The rest is really up to your imagination. But the idea is to separate functions so you can change them on the fly rather than bake them all into scenes or chases.
Good luck.
Nathanrs93
Re: Submasters
I see what you mean and thanks for the information and tips on what I can do. I'll certain be looking into different things when I get chance :)
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Re: Submasters
Post by Uriahdemon »
I would also recommend having a look here - http://www.freestylersupport.com/wiki/p ... _submaster
Rgds
