Hi all,
ok i'm little new to Freestyler but its very similat to light jockey so it is not so hard for me.
i have a problem, i created a scene which i want to use with the flash buttons but it always keeps "frozen" at the first step. If i use it in a sequence/submaster it works. which parameters should i change? Its a simple movement from the bottom to the top for 5 scanners => 2 steps.
Or is there another workaround/solution how to attach this movements to the buttons?
Best Regards
Tomas
Trouble with flash-buttons, what am i doing wrong?? Topic is solved
- FreeStyler Version: Beta
Re: Trouble with flash-buttons, what am i doing wrong??
If it is these override buttons then the only set the first scene in a sequence.
http://www.freestylersupport.com/wiki/p ... de_buttons
The right way is the one with sub masters as you have tried.
jayjay89
yes...these buttons.
thx for the answer.
thx for the answer.
- Spirit
- FreeStyler Version: 3.5.9
and Shapes from the Pan/Tilt window can also be added to a Override button.
and as jan-k Says the first step from the sequence...
