Running in touchscreen interface mode.
I need to be able to have Sequence 01 running on Cuesheet 01 and Sequence 02 running on Cuesheet 02 at the same time, but...
When the DJ presses Sequence 02 on Cuesheet 01 I want it to turn off Sequence 01 on Cuesheet 01 but leave sequence 02 running on Cuesheet 02.
I know that the override buttons can work like this by setting them to "Disable all other buttons"
Can I do this but with the Cuesheets instead but on a per Cuesheet basis?
Or is there an easier way of doing this so a non lighting person can use the software?
Set up FS so DJ can use
JamesLS
- FreeStyler Version: 3.5.2
- Twitter: https://twitter.com/#!/JamesLS
JamesLS
Re: Set up FS so DJ can use
Basically I want the cue sheets to act the same as the overrides in that when you click one it turn the other off.
Or if the overrides can run the sequence instead of just the first step.
- djSupport
I have set up a nightclub that has NO LJ I created a bunch of basic scenes, enabled multi select so you can run more than one sequence in the cue list they simply turn the par cans on running sound to light when needed then run different MAC 250 patterns then set up a buttons page to select MAC colours and gobos then mapped alot of it to the keyboard for example the strobe, If you'd like I'll upload the screenshots, and the instructions I wrote for them maybe you can get some ideas from that? If you have a setup you use when your working just setup a new location file and open that when you work so it loads up all your stuff!
