Laserworld es-800rgb fixture ? Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: Laserworld es-800rgb fixture ?
hi try this file..
its still in progress i also found some little fault from me. also the Fixture icon is not the correct one.
but most of it is correct.
is says 4000mW because the laser i have got some new Laser module's
RGB 4000mW.pff- (328.29 KiB) Downloaded 130 times
jan.osh
sorry the fixture is damaged and empty ...it is not realy help to creat it
- FreeStyler Version: Beta
4000mW
The pff file is ok. I just checked it.
It is with sub folders and therefore Freestyler version 3.5.0 is needed.
- Spirit
and still the Red beam isnt strong enough...
jan.osh
i downloaded freestyler version 3.5 ..the fixture works...thanks for support
davidhogenes
this 1 is not working @ the es-800rgb it is going on ant off plaece help
