Selectable fixtures
dekw1
FreeStyler Version: 3.5
I Use FreeStyler for: None of your damn business!
Selectable fixtures
Post by dekw1 »
I can create new fixtures ok, but I am unable to transfer them to my list of selectable fixtures in Freestyle.
I am trying to add a StudioDue Giant into my StudioDue catagory,
Can anyone help please/
Cheers, Dek.
Un gel spГ©cial est utilisГ© pour aider si vous avez vasculaire cГ©rГ©bral et de crise cardiaque.
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
Re: Selectable fixtures
Post by Crrispy »
I'm not sure to understand your problem?
Menu: Setup -> Add/remove fixtures and just add your fixtures. or is it something else?
dekw1
Post by dekw1 »
When I go to add/remove fixtures, the ones I have made are not on the list ?
Cheers
Dek. :cry:
have you saved the fixture files correctly?? or filled out the manufacture and name properly?? if your unsure export it then post it in your post.
dekw1
Post by dekw1 »
Sorted :D the fixture files are stored in a "compatability" file in "vista" and need to be coppied into the main Fixture folder manually,
Working fine now :fs:
Cheers, Dek.
Arie Pols
Post by Arie Pols »
dekw1 wrote:I can create new fixtures ok, but I am unable to transfer them to my list of selectable fixtures in Freestyle.
Cheers, Dek.
What is your problem? You can create a fixture, but it wil not appear in the fixture list? I think You forgot the brand name or something like that, I created many fixtures and had in the beginning the kind of problems, alway my own mistakes, have serieus look on what you did, or be more precise about the problem.
