American DJ Majestic LED Topic is solved
Th0r4z1n3
Post by Th0r4z1n3 »
Kinda new here, and just starting to learn about FreeStyler, but I'm looking for a profile for the ADJ Majestic LED fixture. I'm working on it in the Fixture Creator, but am not having much luck at the moment (this is a LOT to take in all at once, LOL). Any help would be greatly appreciated; if someone could point me to an already existing file, or to a good tutorial on how to create one, that'd be awesome.
Thanks in advance
Th0r4z1n3
Re: American DJ Majestic LED
Post by Th0r4z1n3 »
I was over thinking it, I think I got it now. I broke it down to a 2 channel profile which I'll then add 4 times; one for each lens so I can control them independently.
Post by Jan_K »
Sorry! Wrong fixture.
Was a bit to fast looking through the fixture folder.
Is it his one you are looking for.
American_DJ_Mystic_LED.pff
(60.5 KiB) Downloaded 79 times
Post by Jan_K »
Her is one with all function in. All 8 channels
I will not say that it is the best.
Think I personally will prefer a 2 channel fixture because it in a 2 channel fixture is possible to use the strobe channel and the blackout function.
American_DJ_Majestic_LED.pff
(169.47 KiB) Downloaded 71 times
Post by Jan_K »
And here are the 2 ch fixture that are to be added 4 times to cover all 8 channels
American_DJ_Majestic_LED_2ch.pff
(36.05 KiB) Downloaded 68 times
Th0r4z1n3
Post by Th0r4z1n3 »
Thanks Jan, I searched and searched for an American DJ Majestic pff file and couldn't find one to save my life. Looks pretty close to what I came up with, so that'll help a bit as far as learning how to use the fixture creator :D
Looking forward to becoming a more active member of the community
