American DJ P64 LED Pro Topic is solved
keithsplace
Post by keithsplace »
Need fixture for American DJ P64 LED Pro fixutres.
It doesn't show up in FS Fixtures, is there an equivalant fixture for this model?
Works in 3, 6, or 7 Channel Mode. I have the values sheet but figured there was a lot of these out there.
JamesLS
FreeStyler Version: 3.5.2
Twitter: https://twitter.com/#!/JamesLS
Re: American DJ P64 LED Pro
Post by JamesLS »
Could you post a manual to your fixture?
keithsplace
Here is the manual for this particular fixture.
http://www.americandj.com/pdffiles/64pledpro.pdf
I suppose I would use it in 3 Channel mode with FS, although I think that the
channel 6 would be nice for automated color mixing/changing macros.
Not sure how that works with FS yet, any thoughts there?
I also have two unknows brand Spot LED 30w moving heads and two American DJ Concept 1 scanners
that I will be using in the setup.
I normally use 8 P64's for general stage lighting, and colors, but would like to incorporate some mixing and
changing and using the moving heads and Concepts as spots and moving effects.
